Whipple HO coolant psi?
I've got the valve covers back from the powdercoater and am ready to continue the Whipple HO install. I am taking the compressor/intercooler unit to a radiator shop to pressure test before dropping it into the intake. Got a question: what psi does the supplied bosch pump crank out?
RE: Whipple HO coolant psi?
#1 nicely done on the precaution
#2 idk the exact psi, but it doesn't matter imo.
if you cantest it, with say 25 - 30psi,
your golden.
you can also do a leak down test, with compressed air...
your golden.
The cap on the intercooler tank says 10psi.
I don't think it gets very high in normal use though.
I pressure tested mine to 5psi first. I had the intercooler defect so it wouldn't even hold 5psi...
jwog666
12-27-2021 08:09 PM
