Newbie Question about Engine Building.
Okay... I (incorrectly) thought engine building was mainly to have forged internals for when you go FI and not necessarily for hp gains.[&:]
Eventually (in a year or 2), I wanna go with the STS twin turbo setup...and I wanna go with forged internals, but I have no idea what "engine building" entails...lol
Help a newbie out! What do those #'s mean? (298, 302 etc.)[&:]
RE: Newbie Question about Engine Building.
Well, that's a really open-ended question.. engine "building" can be from mild to wild - a simple rebuild all the way to swapping out to forged parts, altering bore and/or stroke, etc... then you get into porting to optimize airflow, blueprinting and balancing, etc.. volumes can be written, I'd seriously suggest a book or wikipedia to get started.
And 289, 302, etc. is the cubic inch displacement of an engine - compare to the metric expression, a 302 is equivalent to a 5.0 liter, etc. Our 4.6 liter engines are roughly equal to 281 cubic inches - it's a little over 60 c.i. per liter, so I use that for rough conversions.
When building an engine for forced induction (supercharger, turbo..) you want a lower compression, I think our cars are somewhere around 9:1? But if you want to stay naturally aspirated (no turbo or supercharger) you want to build high compression.
The compresion ratio our cars have is pretty forced induction friendly.
ORIGINAL: A_J
ORIGINAL: jay0heavenly
ok... thanks for the help so far... I've heard that people don't suggest going higher than 289 b/c they ran into problems going bigger...any insight on this?
ORIGINAL: A_J
Now if you're speaking generally, well you'd eventually run into issues making any block have significantly more displacement than the design can handle - try to get extreme with bore and stroke and you can start running into issues such as cylinder walls too thin, interference from the stroke being too long and pistons getting stressed, etc.
But a good rule of thunb for the uninitiated would be to go with a stroker kit from a reputable source - they've likely sorted out any potential issues. Also note that displacement, and compression ratio, can be altered somewhat by the choice of heads (combustion chamber size).
You can always take the easiest route and just buy a stroker short block, then you will only have to chose a high compression or a lower compression for FI and not have to worry about the walls being too thin.
wait for Fordfanboy to post in here, he's one to talk to about built motors. I think he had a 302 stroker at some point, but is now with a 289 I believe, which is supposedly better because you can leave the knock sensors on.
08-28-2015 01:05 PM
HIS S-197
08-10-2015 05:47 PM
