My throttle delay comments...
Old 10-11-2007, 08:09 PM
  #21
howarmat
s197 Junkie
howarmat's Avatar
Default RE: My throttle delay comments...
venom, who did your tune?
howarmat is offline
Old 10-11-2007, 08:41 PM
  #22
MustangEsq
MustangEsq's Avatar
ORIGINAL: howarmat
Yeah i did the gas pedal trick a couple days ago....nothing different, but like i stated, i do not feel that my tune has really lost anything either
I hear that alot from you manual guys....I think it is more noticeable on autos...
MustangEsq is offline
Old 10-11-2007, 10:56 PM
  #23
v6VenoM
v6VenoM's Avatar
ORIGINAL: howarmat
Doug did my tune. And he even sent me an updated tune because I called and told him I still had lag. No difference.
v6VenoM is offline
Old 10-12-2007, 10:23 AM
  #24
ski
ski's Avatar
ORIGINAL: v6VenoM
Did his updated tune contain this revision?
http://forums.bradbarnett.net/showpo...p;postcount=62
ski is offline
Old 10-12-2007, 03:37 PM
  #25
v6VenoM
v6VenoM's Avatar
No it didn't. Do you think I can contact him and get that?
v6VenoM is offline
Old 10-12-2007, 03:50 PM
  #26
v6VenoM
v6VenoM's Avatar
I just called Doug and he sent me a new tune. He disabled the adaptive learning feature for me. I hope this cures the problem. I am going to install this tune as soon as I get home and see if it makes a difference. SKI thanks a lot for that info, I really appreciate it.
Mike
v6VenoM is offline
Old 10-12-2007, 04:03 PM
  #27
howarmat
s197 Junkie
howarmat's Avatar
Being able to turn the adaptive learning feature for the auto trans should help them out alot....I think this is why the manuals dont seem to have the lag problem return once turned, its one less thing that the CPU cant change.
howarmat is offline
Old 10-12-2007, 08:12 PM
  #28
Mikes_BLK_GT
Mikes_BLK_GT's Avatar
I havnt experienced this yet but most of my driving is city. I do hit highway speeds for a couple of miles but thats about it. I have multpile tunes and switching to me isnt that big of a deal, infact it can be fun. I have no throttle lag, when I step on the gas it goes. As far as my post count well I tend to spend a lot of time on this forum so that fact I have that many posts just shows I'm active on the forum nothing more. There are people who know alot more than I do and people who know a lot less, post count has nothing to do with it.
Mikes_BLK_GT is offline
Old 10-13-2007, 09:57 AM
  #29
ski
ski's Avatar
You're welcome.
ski is offline
Old 10-14-2007, 08:31 AM
  #30
GT John
GT John's Avatar
ORIGINAL: grampa_stang
Now, the dead pedal space is a different story...tune can't fix that one.
Thats a mechanical issue that can be easily corrected. (without removing the gas pedal).
The way I corrected mine was to cut a piece of aluminum approx. 1" square (I cut up one of those small aluminum placks that you get at car shows - dont know the thickness). Bend 3/16" of one end to approx a 22.5 deg angle.
Get in the car, lay on the floor push the gas pedal down so that you can insert the new piece. To hold the piece in place you can use a piece of that 100mph UPS tape.
Start the car, let it come down to idle speed. If the engine does not come down to idle, then you know the thickness of the piece is too much. Or, if you still have a dead space then you know you need a thicker piece of material.
Everytime you start your engine the ECM determines what is zero gas pedal position.
No more dead space in the gas pedal here.
The other method requires surgery of the gas pedal unit. I cant go there, eyes are bad and cant hold my hands steady enough.
Just to keep in line with this threads topic.............my car has no hesitation. When I push down on the gas pedal..........it goes.
GT John is offline
Quick Reply: My throttle delay comments...
