anyone running aftermarket clutch for DD??
I just installed a spec 3+ super twin w/ aluminum flywheel. Anyways today uring rush hour I had the toughest time in the stop and go traffic and actually noticed it was easier taking off from a stop in second rather than first. Everytime I took off in 1st I was chirping the tires. Second gear was a little shaky but I slipped the clutch out slowly. I guess my question is what is better for the car/ clutch taking off in second slow or chriping 1st almost everytime? I also think I am having more difficulty since I have 3.73's in the diff. At this point I am wondering about just doing 4.10's and swapping for a 6 speed tranny and just forgetting about 1st altogether..opinions suggestions?
RE: anyone running aftermarket clutch for DD??
I have put in the Fidanza twin disc with the Aluminum flywheel. It is good but I know what you are talking about with the "On or Off". I will say however that the Fidanza is good in first gear take off as long as your RPM's are up a little. Over all I am happy with it.
Yeah "on or off" is an excellent way of putting it. I am really starting to think about garaging the 'stang and getting another DD. When I started down the "mod road" I lived 5 minutes from work in Arizona. Now I live in San Diego, have a 45-60 minutes rush hour commute in stop and go traffic on the freeway, and to add to it, the hills are beating my front spoiler up bad. [:@]
I honeslty didn't think that the stage 3 would be that difficult to engage, I thought there would be somewhat of a friction zone. I am hoping that the clutch still just needs to be broken in.
The problem with performance is you give up something. With the Performance clutch you give up a little drivability. Sorry to say I don't think it will get much better with your clutch, it's the nature of the beast so to speak.
ORIGINAL: 07SCGT
Seriously, why not go back to stock gears? it'll smooth your acceleration and minimise wheel spin. and with 450 rw torque you won't need 3.73s IMO.
I have the spec 3+ with fidanza flywheel and first gets a little easier. I only have around 200 miles on it and it keeps getting easier to drive. But rush hour would still suck.
usually it takes 500miles to break in a clutch. how many on yours?
i have the same clutch - after about 2000 miles it's much much better. I actually thought mine had issues because it was SO hard to drive at first, but now it's not much different than stock. just give it time
ORIGINAL: Stage4
My centerforce is pretty smooth in rush hour. Pedal pressure is a bit more than stock but nothing inhumane.I've heard that while pedal pressure is stock-like on the specs the engagement is like a light switch. I have 4.10s and 2nd gear starts are pretty smooth although 1st is managable too.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
