Normal water temp?
Normal water temp?
Someone pm'd me asking what my water temp was while cruising, idle, etc. I realized I didn't really know what was normal for a NA mustang gt. I've seen my cylinder head temps go up to 205-210 when driving slowly or at idle. cruising it's 190 so coolant temp is probably a little less than that. If you have a temp gauge on your non-supercharged mustang, what does the temp usually read?
I have an aeroforce gauge by the way, that's why I can monitor cylinder head temps. It monitors water temps, but I don't really check that often, so don't remember what it reads.
RE: Normal water temp?
thanks, ignore my pm then.
Is that with a whipple or naturally aspirated?
ORIGINAL: hammeron
someone with an engine coolant temp
gauge, just told me this the other day....
about 180 - 185* while the car is moving
it can climb up to around 210 -215* sitting in traffic
hammeron i believe that was me i have the H.O. whipple. i asked both of u the same question because i didnt know who had a temp gauge. my car while cruising is around 180-190 while sitting it goes up to 210 i wanted to know if that was normal for superchargers?
maybe another booster with an
engine coolant temp gauge, can chime
in and shed some light on the situation
i know my cluster h20 temp "gauge", sits where
it always has....before and after the s/c
jwog666
12-27-2021 08:09 PM
