CMCV Delete Question
RE: CMCV Delete Question
no no. my car basically wants to stall in first unless i give it more gas. I tried to clean the tb, wasn't so dirty. so i was wondering if the udp would release more power and free up stress on the tension and my rpm's would be ok when starting in first
Did you just install the plates & tune? Do you have an intake? Make sure everything is on tight and that you put the MAF sensor in the right direction. If all that checks out, maybe there is something wrong with your tune.
ORIGINAL: acascianelli
Why do you think you need to install a UDP at the same time? All you need with delete plates is a tune.
I don't know of any canned tunes that work with delete plates. I know my Predator doesn't have any canned tunes for delete plates, thats why I had to order one from Bamachips. Like I said before, you need a custom tune that will adjust for the delete plates.
I'm assuming the 07 in your name means you have a 07 Mustang, I would suspect the fuel filter and a dirty TB to be the problem. Contact Brent, odds are its a problem with the tune. If you don't have the proper tune for the delete plates, I think brent will write a new one for free.
You could try reflashing the tune again, I've heard that works sometimes.
