Can't Chirp 2nd!
Can't Chirp 2nd!
Reasons for my inability to chirp 2nd gear? (mods in my sig)
1- You just suck as a driver!
2- Brand new 285 KDW2 tires too grippy?
3- Loaded Brenspeed 93 tune wrong??
4- TCS off or on?
5- You just suck as a driver!
4- TCS off or on?
RE: Can't Chirp 2nd!
1- Could be...?
2- Cannot say.
3- My god man...I can chirp 2nd with the stock tune, so if you can't chirp it with that tune, something sure is wrong.
4- Bleck, def. turn TCS off
5- See #1
Had you been able to chirp 2nd before the a) tires or b) tune?
Of course, I've got a manual. If you have an auto, then maybe that changes things...
2- Cannot say.
5- See #1
ORIGINAL: Larmo
4- TCS off or on?
4- TCS off or on?
2. That is what i have also, it plays a big role....i cant smoke mine anymore
3. prolly not
4. prolly not
5. read above
Are you auto or stick
I've got a stick... never been successful in chirping second, although laid good rubber in first. So it sounds like I just suck as a driver. Maybe I'm just babying the throttle too much in mid-shift?
thanks guys, seriously. So you're saying I'm letting the clutch out too slowly? This is my first stick car and I guess it just scares me a bit to let the clutch out so quickly at WOT.
1. Probable?
2. I have the same and they will in second even before the S/C and before that with stock tune.
3. Reload the tune and make sure you have 93 in tank
4. Should not matter asI have done it with or without the TCS on
5. What do you think......regardless whine her out to 6000+ RPMs and slam it into second....it should work!
ORIGINAL: howarmat
1. Maybe
3. prolly not
4. prolly not
5. read above
ORIGINAL: Larmo
4- TCS off or on?
4- TCS off or on?
3. prolly not
4. prolly not
5. read above
I have the 3.31 gears on a completely stock car and I can get the back end to come out in 2nd on occasion and if I'm really hitting my shifts I can chirp 3rd too. So I don't see why you shouldn't be able to do it on a modded car.
