Vibration from Spydershaft
I have vibrations now that I have the shaft on. They aren't bad unless I go highway speeds and play. Is it just something I have to live with and is it doing harm? I have the solid motor mounts from JDM also. I can tolerate it in town, but at higher speeds it's worse. I like the shaft otherwise.
RE: Vibration from Spydershaft
Id get that looked at soon. Either the driveline needs balancing or the install might be a lil off. Can cause excessive wear on the tranny output shaft bushing or bearing whichever it has and can wear out the pinion bushing in the diff. Both would result in oil leaks after a bit.
ORIGINAL: howarmat
Check to see if the bolts are over torqed....this was a problem for someone, maybe moosestang, cant remember for sure.
ORIGINAL: MexGT
check pinion angle.
check pinion angle.
