Detroit true track
RE: Detroit true track
ORIGINAL: drbobvs
I'm getting a new gearset while I'm at it. Once that ring gear comes out, you'll NEVER get it back in the same way again and they WILL make noise.
Oh, and you won't ned to add friction modifier afterwards since the Tru Trac is all gears inside.
But as far as the trutrac, very good buy. Strong, quite and it grips.
ORIGINAL: androdz
Just so you know if you are under 600hp or so get the true-trac if you are over that get the locker. The locker is very very very aggresive, a tad to aggresive for my likes.
Andrew
Andrew
I ordered from drivetrainspecialists.com, great guys, fast shipping
http://www.drivetrainspecialists.com...ruetrac-1.html
It will give you much more even power delivery side to side. Look at my video here, watch what happens on the second run with the TCS off! This should prevent that.
http://uk.youtube.com/watch?v=SQkkZwlnoxQ
It will also help eliminate that annoying dendency for the rear of the car to kick out towards the drivers side if you lose traction on the launch. Ifixed it by adjusting by D-specs accordingly, but this will be just for good measure.
ORIGINAL: Simon1
For those who haven't experienced this, can you explain more?
ORIGINAL: androdz
Andrew
Andrew
Andrew
ORIGINAL: drbobvs
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
mungodrums
Suspension
09-24-2015 10:12 PM
