Back from the Dyno, What do you think
RE: Back from the Dyno, What do you think
ORIGINAL: moosestang
I don't think you are, even hellion would question your dyno run.
ORIGINAL: wadman
Wow, that seems very weak. Im putting down 492 with a single turbo and 7# of boost.
Everyone needs to remember that dynos are only as good as the people who run them. There are alot of settings and perameters put into a dyno to try and get the most accurate reading.
A dyno should be used to increase power from the base line and or smooth out or improve the power curve.
The real test is when get to the strip and see.
Or when you have a before and after dyno graph from the same dyno in a reasonable time frame.
Here is the dyno graph. Thanks for the responces. One thing i want everyone to know is that my tuner did ask if he could lean it out more towards the end to get more power. I opted not to in fear of doing something to the engine. Im not to sure how far you can push these things and where the perfect air/fuel is at, so i made him keep it rich. He also wanted to up the boost but we are boosting off the waste gates so its a pain in the *** to shim the turbos on the dyno I also do want to push it hard. I figured i would run it like this for a while and when i find out more info then up the power. or hopefully build the bottom end. Again let me know what you all think. Thanks
Please note that this kit has to potential to go to about 12 PSI any furthermy air to water intercooler will not be able to handle
the a/f needs to be leaned.....it should hover around the red dash line...no offense but the tuner was correct and you yourself stated you didnt what the a/f should be or what you were doing...so when someone who does know what there doing asks to lean out the a/f for you, you should let him, this is his job after all
ORIGINAL: howarmat
