Purge flow valve problem
I have a '96 Mustang that is getting a P1443 code. I have done a lot of the stuff on the forum to try and troubleshoot the problem. I narrowed the problem down to the Purge flow valve. I have replaced the valve twice with a brand new valve. It is getting around 12 - 13 volts to the electrical connection on the Purge Flow Valve, but the valve is not opening. I checked the vacuum on the inlet side and there is a very strong vacuum there, but no vacuum on the outlet even though voltage is going to the valve. Is there anything else that could be causing this problem? Thank you,
Craig
Craig
RE: Purge flow valve problem
welcome to the forum
if it's a 1996, you'll want to create a new
thread here:
https://mustangforums.com/forumid_4/tt.htm
good luck and i hope you fix your
problem
thread here:
problem
Luke9222
10-22-2015 11:55 PM
TfcCDR
09-14-2015 12:08 PM
zanemoseley
09-06-2015 12:58 PM
