need a new clutch
RE: need a new clutch
ORIGINAL: exx1976
What brand clywheel/clutch did you get? I'm gonna be in this boat soon.. Well, soon as the Saleen group buy goes through.. :-)
ORIGINAL: wadman
What are the indications that you need a clutch? Ive run the snot out of my car and as far as I know its still fine except from some popping sounds.
ORIGINAL: 06Saleen3V
The easiest way for me to tell is you will feel it physically slipping like leaving in 1st from a stop
ORIGINAL: wadman
ORIGINAL: wadman
1. Parking Brake On
2. Engine On
3. Place in 4th Gear
4. Rev To 3000 rpm
5. Slowly Release Clutch
If it stalls your good.
If it keeps running, new cluch time!
ORIGINAL: wadman
Not to mention it's winter time and I would like to have my car race ready for the spring and I don't want to be interupted. And I have the money.
I did probably 25 runs on the clutch with simple bolt on's.
25 runs, spraying from the line. Then figure out all the other BS and it adds up to alot.
5 runs witht he turbo. And a slipping clutch with the DR's on. It didn't slip the entie time but I could feel it catch and release.
ORIGINAL: Gene K
Per Ford Service Manual
1. Parking Brake On
2. Engine On
4. Rev To 3000 rpm
ORIGINAL: wadman
1. Parking Brake On
2. Engine On
4. Rev To 3000 rpm
Is it Fidanza? just trying to help! Heard they make a good aluminum one! J
I am having a brain fart right now and cant think of the brand of flywheel which is embarrasing. The clutch is McCleod which is top of the line...very, very good clutch. The owner of Hardcore Mustangs has used Spec, Centerforce and all that crap on his 550rwhp stang and he said McCleod is by far the best he has used. Ill get back to you on the flywheel
ORIGINAL: exx1976
I think I need a new clutch too, Because mine starts slipping around 120 to 140+. It is still the factory clutch. I was thinking of buying the Spec stage 2 with aluminum flywheel. Does anyone have the Spec stage 2 and aluminum flywheel on thier stang? how does it feel?
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
