A/F problem troubleshooting
So I installed my A/F monitor system, and this is what I am seeing. When I start is sits around 14.5, but after a few minutes it starts fluctuating all over the place. When I go WOT, i see the number got around 12.? then it starts fluctuating all over the band as well. I am pretty sure it isn't that my car is going way lean then rich.
I haven't seen anyone else with A/F gauge, but I imagine this is NOT normal. Am I correct in this?
Here are my 2 thoughts.
Either my ground is not grounded correctly. I will get some wire for trouble shooting purposes and start with this and touch certain grounding points.
2nd thought, my sensor is bad. When I installed it, I needed to drive it off the ramps to install the main unit. I know you are not suppose to runthe car with the sensor not powered. I started it, backed off the ramps, and turned the car off quickly. Could this be enough time to actually damage the sensor?
RE: A/F problem troubleshooting
My tuner explained that when the car is not under WOT, the wide band is in "lambda mode" whatever the hell that means. It will fluctuate back and forth from high 13's to 15's just cruising around. Under load or WOT (boost) it will go right down and should give a great reading of the actual A/F.
My tuner also said that some times he has seen the cats cause a "swirling" effect. The air would swirl around in front of the cats and cause the reading to fluctuate a little. Not all cars but some.
perfectly normal. your a/f will not be constant when the throttle is being varied (depressed/lifted). at a steady speed, throttle position, ur a/f should remain around the same area. Its when u let off the throttle, u see the a/f go everywhere, first lean, then rich, then slowly back to stoich.
we are talking about a wideband gauge correct?
and, no, u shouldnt be able to damage the sensor that way.
Seanam
10-04-2015 10:15 AM
stangin1996gt
09-21-2015 11:01 AM
