SLP loudmouth hangers
Hey guys. Do any of you guys have problems with the SLP loudmouths moving a little bit after you install them? My driver side set up matter how tight I make it moves a little bit making it go off center. It was perfectly centered for about three weeks but than it gradually began to move. I have taken it off and redone the entire thing so that it does not shift...but it didnt work. Anyone have any suggestions as to what I could do?
RE: SLP loudmouth hangers
i thought i was the only one with the same exact issue - my left side passanger side even brokeoff and left a hole in the pipe. i dont think the claps where tight enough which might have caused them to move or slide in and out expecially with those pressure vibrations they give off -
i tighted the clamp bolts and so far so good no movement
I just installed a set of powerflo's and didn't tighten the exhaust to midpipe clamp enough and after taking it for a test drive the exhuast pulled right off the midpipe, so I really tightend it down. My passenger side exaust is not centered though and touching the bumper so I will probly take it off and try to bend the hangers alittle tomorrow.
ORIGINAL: Mustangansta
Nem- I used an impact wrench I guess I just need to tighten it some more. I will add it to my "to do" list once spring gets back around....I can't even hear the exhaust until the snow is gone
ORIGINAL: whtcanbrwnd04u
Mine are fine. But when i cold-start it.. the left one rattles, i havent looked for the issue yet, but its really annoying me.
Galactic
04-29-2019 02:56 PM
New Era Performance
08-09-2004 04:36 PM
New Era Performance
07-22-2004 02:59 PM
