new tires
new tires
So i am going to be buying tires soon. Wanted max performance summer, but i go to tire rack and it is 200 dollars per tire. the rossis were 270. and that is with the stock width of the tire. If that is the goign price then by all means thats what i will do, but i was hoping to get a cheaper tire. Also, wanted to know whats the widest i could put on the 18 inch rims, 235s just dont do it for me. Thanks
RE: new tires
Probably 255/45-18's, although for a couple of reasons they may not look very much different from 245/45-18's on the same wheels. I hear you about that 235 number.
I say 'probably' because even though 8" is (just barely) an acceptable rim width for that size, Ford puts 255/45 front tireson 18 x 9.5's in the GT500. 265/40's and 275/40's REQUIRE at least a 9" wide wheel, 285/40's want to be mounted on 9.5" minimum.
Top-shelf 18" tires do tend to be expen$ive . . .
Norm
Norm
RE: new tires
ORIGINAL: Norm Peterson
Norm
Norm
RE: new tires
ORIGINAL: slySTANGguy
using the 255/50/18, they only have one type of tire that will fit, i need to get the same profile as i have right now which is 50 right?
Those optional sizes you just posted are the GT500 sizes, pretty clearly picked by Ford to match the 27" OD of the 235's. With the GT's 8.5" wide rims you could run the 255/45's on all four corners.
Norm
