Will I mess something up?
I have a diablo sport tuner and 39lb cobra injectors. I plan on buying a vortech tuner kit and using my 39lb injectors and leave my fuel pump stock. For the tune, I will be using the stock diablo tune, until I can get up to a dyno shop and get it properly tuned. (within two weeks, and my car is a weekend car).
Two questions.
1) Is there a parameter in the stock vortech diablo tune that would modify anything for the aftermarket fuel pump that the entire vortech kit supplies?
2) If so, is it something I can modify myself for the time being, until I get tot he dyno shop? (I will stay out of boost and try not to drive it until i get to the dyno)
Thanks for your help!!
Two questions.
RE: Will I mess something up?
IMHO you are going about this backwards.
Get your fuel system up to snuff - arrange for a dyno tune and THEN work on the vortech.
If it were me I would NOT drive my car with a SC installed without having already upgraded the fuel pump and having the correct tune.
ORIGINAL: LMM1967
How am I going about this backwards? I have a vortech tune ready to install when i install the blower. Im just using it in order to be able to drive to the dyno shop. How am I suppose to install the vortech and not drive it to the dyno shop?
You guys are not understanding my question, I am asking wheather or not the tune from vortech for the blower will be chaning any parameter for the fuel pump. Because I am running a stock fuel pump and the tune that vortech supplies for its kit has an aftermarket fuel pump.....
ORIGINAL: 1998YellowStang
"**Tuner Kits do not include MAF housing or fuel management, or engine management, which must be provided by the installer for proper engine operation."
Again - IMO - not following EXACTLY what the manufacturer is telling you to do could turn out bad for you. They know more about their product than anyone on the internet - listen to them.
Don't use wide open throttle and you should be fine until you get to a dyno. If this is on a 05+ gt you may not need to upgrade the fuel pump depending on the amount of boost. The vortech tune is for 39lb injectors right?
Yes, the tune is for 39lb injectors. Also, Ill be using the stock pulley which I believe is 7lb pulley.
Sorry, I do have a 2007 Mustang GT 5-Speed.
I still am confused about your question. Are you upgrading the fuel pump or not? Like moosestang says, Brenspeed is very helpful with questions like this. (They supply a trunk-mounted boost-a-pump with their Vortech kit.)
Sleeper2
Sleeper2
