Monster Collaboration!! Lethal Performance, Fore Precison Works & Zone-5 Performance
Monster Collaboration!! Lethal Performance, Fore Precision Works and Zone-5 Performance Products!
You read that right!! A Monster collaboration just took place between Lethal Performance, Fore Precision Works and Zone-5 Performance Products!!
We're going to keep on hitting you guys with the most innovative high performance products for the Mustang Market and you guessed it the S197 and GT500 guys are next!!
The three of us are working very closely on our next fuel system upgrade project. If you thought the Fore Precision Billet Hat and Zone-5 Modified FPDM was all we had you were mistaken.
Up until now the S197 market has been very limited on fuel system upgrades. For the most part if you wanted something more you'd either have to stick with the GT500 fuel system or hack up your stock GT system to accept dual pumps. If you chose to add a pump to the GT assembly you shorted yourself from the efficiency of the dual driver setup that the GT500 system offers.
Therefore we knew there was a lot of room for improvement, and improvement is what you'll get!
We will soon be releasing the only real solution for you guys that want the best .
For all you Blown, Turbo'd and crazy nitrous people you'll never have to worry about fuel again!
We'll be posting updates as the project moves along so sit back relax and wait for the storm to hit!!
[/align]
[/align]
RE: Monster Collaboration!! Lethal Performance, Fore Precison Works & Zone-5 Performance
What else can I say but we don't play games here!! This is the real deal!
S197 Triple Pump Fuel Hats in the House!!
[/align]
[/align]
Fore Precision Works is taking this design straight to production with a couple small changes. The changes are:
1. Stainless steel eductor discharge tube (instead of copper, portion that exits between the pumps)
2. Add provisions for an adapter to merge into the stock fuel line at the tank. This will be an optional piece for a two pump configuration only...if you're planning to run three pumps, you're probably not worried about using the stock fuel line.
3. "FORE" engraved on the top of the hat.
Lethal Performance will be selling this assembly in a base configuration that is ready to go with two pumps, to be used to aftermarket fuel line. We'll also be offering the following configuration options that can be purchased with the hat, or at a later date.
1. Stock fuel line adapter (for two pump configuration only)
2. Three pump upgrade kit, to include a 3-1 y block and some additional hardware.
We should have pricing and availability information available at the end of the week!
During testing today at Fore Precision Works Justin noted that the installation was fairly simple. The Fore Precision triple pump assembly is actually SMALLER than the GT500 pump assembly.
I look forward to seeing the pricing on these beautiful options for the S197 stangs! Thanks J
You guys ever thinking about a return system kit?
Also - is this triple pump system operating off the single driver module?
Lastly - is there a way to incorporate the GT500 system with dual DM's for those that have to a three pump system using the 2 driver modules?
CK
CK
