O/R xpipe
RE: O/R xpipe
Like Nickelz said O/R simply means off-road which inturn means no cats. To tell if your midpipe has no cats simply look under the chasis to see. If your midpipe has a rectangular box that it runs into and out of then it is catted, but if there is just pipe from your headers to the axle then you have O/R pipe. To answer your other question yes, a catted Xpipe will add some additional HP. The main difference between O/R Xpipe and Catted Xpipe is how loud they are. The cat tends to somewhat muffle the exhaust and you don't get as much sound as you would with an O/R pipe.
RE: O/R xpipe
ORIGINAL: Import Killa
Yeah but wont that throw your check engine light on if you run with no cat's. How can you get away with that.
trashxtrash
09-20-2015 10:49 PM
