My mod list...
My mod list...
Certainly not advocating or preaching to any one of my mods and it is all personal opinion and experience from trying different things but I'm always asked about what's on my car so I thought I'd make a parts list. Remember that what may be good for one build may not be good for another so know exactly what you want to do with your car before shopping for any mods IMO. Anyway, the list...
POWER
4.6 Ford Boss big bore iron block stroked to 331ci
Oil squirters
Diamond custom .020 over coated pistons
Kellog 3.800 stroked forged crank
Manley I beam rods
ARP head studs
MMR rear engine cover/support
Livernois custom p/p heads
1mm oversize inconel intake and exhaust valves
manely titanium retainers and springs
brass/bronze valve guides
Competition Cams part #127300 with a 15 lsa
Canton windage tray
Morroso eliminator oil pan
KB lower manifold
Whipple 3.4 HO with custom coated rotors
custom 4 1/2" intake
custom TB
custom meter
custom upper manifold
Custom motor mounts
custom intercooler resevoir
Mezuire eH20 pump
ST frankenstenioner
Battery relocation
fuel shutoff
Summit COP's
KB boost-a-spark
custom oil seperator
VCT delete
Custom electrical fuse routing - (becomes neccessary when you get a butt load of mods running on the same relays...)
Fluidyne raditor
afco dual pass heat exchanger
Custom intercooler pump
8 rib pulley system
JBA titanium ceramic coated long tube headers
Custom H-Pipe
Mac Axelbacks
Roush tips
Tuned with Diablo predator
FUEL
GT500 fuel system
Dual 40 amp BAP
-8 lines throughout
Custom metco high flow fuel rails
Seimens #60 lbs. injectors & adapters
TRANS
Custom art carr 4r70 full manual with no lock-up and no kickdown - custom built by Larry's transmissions
BMR ratchet shifter
Transbrake
custom 1 piece steel DS
detroit locker
LPW low profile girdle
3.73s gear - but going down...
moser sfi 31 spline gun drilled axels
9" tube welded housing ends
2 BMR trans coolers - 1 diesel and 1 fan pack
SUSPENSION
metco upper and lower CA's
BMR chromoly panhard bar
BMR extreme antiroll bar
MMR coilovers with 3 way adjustable shocks
welded boxframe sub frame connectors
Welded upper CA mount
BMR tubular K-Member
BMR tubular a-arms
BMR radiator support/swaybar delete
Tokico D-spec front struts
RUBBER
Nitto 555r 305/45-18 on the rear and NT555 285/35-18 up front for the street
MT ET Drag slicks 28/12.5-15 on 15" Bogart welded RT's in the rear and MT sportsman front radials 28/4.5-15 on bogarts up front for the track.
I think that's it - I may have missed or forgot a couple things...lol
The rest is either stock, gauges, or appearance stuff...[8D]
POWER
Oil squirters
Manley I beam rods
ARP head studs
Canton windage tray
KB lower manifold
custom TB
custom meter
Custom motor mounts
Mezuire eH20 pump
ST frankenstenioner
Battery relocation
fuel shutoff
Summit COP's
KB boost-a-spark
VCT delete
Fluidyne raditor
8 rib pulley system
Custom H-Pipe
Mac Axelbacks
Roush tips
FUEL
GT500 fuel system
Dual 40 amp BAP
-8 lines throughout
TRANS
BMR ratchet shifter
Transbrake
detroit locker
SUSPENSION
BMR tubular a-arms
RUBBER
RE: My mod list...
Can you spare a bit of money Mark ?
lol j/k ..... very impressive setup !! ... for a very badass ride ! [sm=happy046.gif][sm=hail.gif]
Keep us posted with good info & knowledge !!
