Self lubricatinv vs. oil tapping S/C?
I was juts curious if anyone knew the any pros or cons of havinga self lubricating centri supercharger vs. one you need to tap into the engine oil. Obviously it will be an easier install and I think you'll have to service the actual charger more, but other then that anyone have any experience with the two?
RE: Self lubricatinv vs. oil tapping S/C?
pros for self lubricating is that it never has to be changed! (Whipple or KB says like 100,000 miles) and modaddict recommends every 50,000 miles I think (check the 4.6L section for info). The S/C that requires a tap into the oil pan has a good pro as well and that is the oil is chaged every 3000 miles when you change the oil for the car. Cons IMO is extra piping to get clogged and/or come loose (maybe) but either of the types have been proven to work for the S/C's they are applied to.
EDIT: If you want me to move this to the 4.6L section just PM me and it will be done! Might get more responses there....J
ORIGINAL: slvrstang2007
Paxton has now that option and it seems to be a no-brainer. Less piping, no need to punch holes in your oil pan, shorter installation time, and the oil of the SC can be changed without removing the unit, IIRC.
I'm considering a NOVI 2200 and if I go down that route I think it will be the "SL".
Ya that makes sence, I've only head good things about the procharger self lubrication unit, thinking I might go in that direction thanks for the comments.
jwog666
12-27-2021 08:09 PM
