$1000 to spend on mods...IDEAS????
RE: $1000 to spend on mods...IDEAS????
ORIGINAL: rustic2169
That's funny you should mention that Haze, I was just doing some research on that. I just got off the phone with Brenspeed a while ago and they said the biggest thing with this S/C is that I'll be pushing around 480 rwhp, so traction will be an issue. They suggested LCAs and some DRs if I wouldn't be driving much, but I still do drive my car a bit, not a DD, but enough to where it's pointless to have DRs. I don't go to the track yet, not enough time, but I do occassionly have fun on certain roads (no flames on this please, I hear enough and read enough and it won't help to answer my questions).
So anyway, I've done my research and this is what I have come up with:
BMR HD Rear Sway Bar 269.95
BMR LCAs 134.95
BMR Panhard Bar and Brace 209.90
Steeda "G-trac Brace" 69.95
BMR UCA 135.95
BMR UCA Mount 134.95
Total is about $50 under my $1000 and I think that would be the biggest pay off in preparation for the S/C. I got all my info from CrazyAl's post a while back.
BMR LCAs 134.95
BMR UCA 135.95
Get an adjustable Panhard Bar.
Get adjustable LCAs.
Get an adjustable UCA.
If you're going to do the rear sway bar, do the front. Otherwise, you're going to create a REAL bad oversteer (or is it understeer? Someone will chime in and straighten it out - Norm Petersonperhaps? Or Sam Strano maybe?)problem because the rear will be stiffer than the front, not a good idea.
My suspension mods that I'm planning are as follows (disclaimer - this will break your $1k budget, but..)
H&R sport springs (I don't want a HUGE drop, doing side-exit exhaust soon - already ordered it, just waiting for it to show up at the body shop) (~$250)
Koni adjustable dampers (~$700)
Adjustable LCAs(~$250?)
Adjustable UCA(~$180)
Adjustable PHB(~$150)
The other thing you might want to look into is wider rubber.. For $1k you could order a set of wider wheels, and get the rubber later..
The 1-piece DS is also a good idea.. I have that on my list at some point this season..
ORIGINAL: exx1976
I still have 3.55's in mine, but if I'm not mistaken, you can change gear ratios yourself with the XCAL2, no?
NO !!!!!! Don't make the same mistake I did, yes you can update the ratio in your XCAL2 but that only adjusts your
speedometer. When I upgraded to 3.73s I loaded up my tune and adjusted with the XCAL to 3.73 and I thought everything
was great, butthen I drove the car and it didn't seem much different than when I had the ole 3.31s, in fact worse !!!! I called up
Bamachips and Dougsaid you need a new tune dude, he sent meanewonemadefor the higher gear ratio andwhammy !!!
Funny thing is this time I uploaded it without changing parameters and the speedo was all screwed up, now at least I knewthe car
wasset-up for the correct gear ratio, I made the change in XCAL and re-uploaded and now I am ingood.
The seat of the pants responseactuallyUSING the better gear ratio is awesome, now I have to put it to use and see if I can get into the 12s!!
Just goes to show a BSEE. doesn't mean anything when your dumbto begin with[]LOL
thanks
I've also been toying with the idea of a wider tire in the back, any ideas on a good size and brand? I've done some research, but still can't make a good decision. The M/T Streets are just not a option for me, I drive just enough to where they would burn up in a year. I want this thing as streetable as possible with this S/C and that's kind of what I'm trying to decide with this pre-S/C $1000 mod money. I just don't want to be at a light and then roast my tires so bad that someone in a stock civic will get like 5 lengths before I hook.
I was actually looking at Saleen S/C's today, just for pricing, but it seems to be more that what I want to spend. I know, people would say, then just add the $1000 to your S/C money, but that would do nothing for me. I would have all this power, with nothing but stock suspension and the stock pirelli's trying to keep me in line, and I also like the power I get out of the Paxton kit for the price. I already have the SCT X-Cal 2 so I get to knock off 210 from the package. But 480rwhp for only 4.5k seems like gold to me.
If I decided to get new rubber for the rear, what suspension mods do you guys think I could drop? I still want to get LCAs (Gonna go adjustable) but I also want to get any other suspension pieces I can if I do decide to get new rubber and still stay at 1k.
Well whiteflash, the gears won't be fun to drive with once the S/C is on and the pulley won't do anything either. The HIDs I want someday, but my dad always told me, "start with the performance first, no one will see what it looks like when it's blowing their doors off". But if I wasn't getting the S/C, then 4:10s were in my plan.
