Rise of the Chevykiller!
RE: Rise of the Chevykiller!
Congrats!! can't wait for the results...
HeyMark, if you don't mind me asking, how did you get 331ci (5.4L) out of the BOSS block? as far as I know the max recommended stroke is 3.75 and that-along with a 3.70 bore- results in 5.3 liters, I've heard 5.4 is possible with a 3.85" stroke crank? and beside saving weight, what advanteges this stroker gives over a normal 5.4L modular block? wouldn't this be easier and (alot) cheaper?
And how about that 5.8L modular block MMR sells?
wow nice man! i wanted an engine build done in september and through many many problems i still dont have my car! wish i was around the competent people you were. props to those shops for gettin shiz done
ORIGINAL: baha
Hey Mark, if you don't mind me asking, how did you get 331ci (5.4L) out of the BOSS block? as far as I know the max recommended stroke is 3.75 and that-along with a 3.70 bore- results in 5.3 liters, I've heard 5.4 is possible with a 3.85" stroke crank? and beside saving weight, what advanteges this stroker gives over a normal 5.4L modular block? wouldn't this be easier and (alot) cheaper?
I used a kellog 3.80 crank and .020 over dimaond pistons to get exactly 330.7ci (331) I had the block sonic tested first to see how far I coud go and this was the safest max without taking too much material away. This block is iron so you don't shave weight and like I said, it's not about being 'better' than a 5.4 motor, it's about being as fast as I can on the 4.6...[8D]
If it was just a matter of wanting to be fast, I would have just put in a 500ci pro stock motor and made it a track car...
It's about trying to get an 8 sec ET with a street driven single power adder 4.6 3V...[&:]
ORIGINAL: Dex
He is for sure not the only one, but my honest opinion is he is one of only a handful of guys in the country that are the pioneers of the S197 and breaking ground on the 3V capabilities. I can name on one hand the guys who would even attempt this build he's doing for me.
