Gauges<--Help me out guys
RE: Gauges<--Help me out guys
No that is the single. The Dual kit is so you can run 2 aeroforce gauges off the one OBD 2. The gauge allows you to look at 2 parameters at one time. You can also have it cycle through preselected parameters on a time basis. It also allows you to set an led light to come on if a parameter goes out of range.
If you buy the dual set up you get 2 gauges and can look at 4 peices of info at one time. To me it wasnt worth it.
The gauge will also record your 0-60 time 1/8 and 1/4 mile as well as compute HP. I havent done it yet but I will soon.
All in all I really like the gauge and recommend it.
Not bad, you just plug it into the OBD 2 and wire in power. Install directions are sufficient. I also recommend the SOS gauge pod. Fits perfect and is good quality (they start with OEM A pillars). Much better than that autometer stuff.
MustangGT0405- Thanks for the pics and advice, you saved me some cash in the long run because I would have went with a cheaper gauge until I found one of these....then I would've chunked the first ones!!
I'd like to get a programmable shift light.
Really like the Roush vent pod option.
So I could install any digital gauge 2-1/16"?
How hard would it be to install?
Fishing through the dash and connecting to tach wires? Thanks.
or
or
ORIGINAL: Darkness7
Sounds like a winner to me. I guess its worth the money considering all the parameters that you can track. How involved is the install?
It will display a gazillion things and it reads and clears trouble codes just like a tuner. Did I mention it records 0-60 and 1/4 mile times?
ORIGINAL: moosestang
the aeroforce gauge simply plugs into the obd2 port under the dash. there's no other wires to run.
ORIGINAL: Darkness7
