stock GT tuned for premium fuel?
"Actually, the engine is programmed for higher octane and the computer can adjust to different octane levels. It's when you put in 87 octane the knock sensors have to go to work.Quote from KB super install. "Ford has tuned the knock sensors so well to the stock engine that the Spanish Oak is actually programmed with premium fuel ignition and fuel tables, but the car is sold as a regular-gasoline car. That means with regular fuel, Ford is relying on the knock sensors to constantly maintain timing because the computer is trying to run aggressive, premium-fuel spark tables all the time."
I read this on another forum and wanted to get your $.02. Anyone know if there is any truth to the above "theory" that the stock GT tune from Ford is for premium fuel and that they (Ford) are relying on theknock sensors to cause timing to be pulled when running 87 or 89 octane?
And no they were not discussing the Bullitt (I know it has this technology).
RE: stock GT tuned for premium fuel?
for the bullit and 09s this might be true.....for 08 and before, yes the car runs just fine on 93 oct and you will have no problems. The computer is not adapting a whole lot for it though.
Best way to dis this is to contant Brenspeed or one of the other tuners to see what the stock timing is set at. If what you suggest is true, it may put them out of business.
ORIGINAL: mhconley
My dealer told me my 2008 GT was tuned to run on regular gas - 87 octane here in California. He said putting premium in the tank was a waste of money.
Martin
Martin
All in how you look at it I suppose. Say you used Shell V power with 5 times the detergents in it than what the govt, demands. It may......MAY keep carbon build up out of the spark plug area and save you a future head being pulled. V power is rated to actually clean deposits out, not just keep them from forming.
Semi-on this topic. I don't know if its been discussed. But does putting 91/93 octane fuel in the tank and tuning via handheld tuner for that octane actually unleash more power from the engine? Or is it just a waste of time?
ORIGINAL: GidyupGo
ORIGINAL: mhconley
Martin
Martin
And yes getting a CAI and tune is not hype.....read the 104523452345 other threads about how pleased people are with the tunes
ORIGINAL: 300GT
