fresh air to CAI
RE: fresh air to CAI
Code:
I am wondering if this would in some way cause the engine to run too lean or anythinbg else troubling that I do not know about.
1) If you installed alarger Mass Air Housing and DID NOT recalibrate the computer with that parameter (lean).
2) If your inlet tube detaches from the throttlebody and MORE air is entering the intake plenum than is being metered at the Air filter Inlet (lean).
Your home made air ductsmay help theair temps to be "COOLER" - any performance difference you would have to fill us in on. I would like to reccommend adding some type of screen or grille to filter out large particles from being forced up through the ducts and clogging your intake. [a pre / post DYNO would tell the story] GOOD LUCK and let us know how it works out for you.
ORIGINAL: 4.0 Stang
Any difference in performance.
junior04
09-28-2015 10:53 AM
09-27-2015 03:16 PM
