Saleen SC install question
RE: Saleen SC install question
Frank,
You have it correct in the first picture. The way you have is now is actually the 'vaccum line upgrade' route developed by JDM. With this configuration your boost will come on sooner and more positively.
ORIGINAL: hotairgypsy
so which do i do...i am currrently set up like the first one
[IMG]local://upfiles/59163/E99BFE60D039417AAE47529DE1E5BFA1.jpg[/IMG]
I shoud add the JDM way was developed when Saleen had routing version 1 where they tied the fuel sensor to the brake booster, the newer saleen way addresses this. And no your boost will not come on sooner and more positively in the JDM vs Saleen version 2 scinero. Think about it, the actuator has to open by absence of vacuum to close the bypass and get boost, it's allready done it's job by the time it sees boost. If you don't believe me turn your car on let it idle and go pulloff a vacuum line and see how fast that actuator opensunder no vacuum.
09-16-2015 02:11 PM
Shifty Magoo
08-25-2015 03:08 PM
