Im going to be getting some manley or livernois valve springs because im going to be running higher boost. is it hard to swap these out and do i need anything special?
Get a shop to do it if you are even thinking about it. It already sounds that you are unsure if you should do it. If this is the case don't even try because youwill f*ck yourself.
