SCT BA 2400 & BA 2800 question
I have a questions if anyone could answer.
Ona builtor stroked motor (500-750rwhp/16--22psi)running a Whipple setupcan youuse a 90mm BA 2400 mafs fromaround 450rwhp-620rwhpor a BA 2800 around620-750rwhp+? The reason I ask is I haven't seen anyone running one on a Whippleof course Iknow the mafia(to stretch/trick themafs v.)can and has been used ondifferent FIsetupsbut itis not a true mafsand imo I would want to run a true largermafs vs a Diablo mafia. The only reason that comes to mind per Mafia (over a BA mafs)is maybe its just easier to tune (& its range)with a Mafia and thats the reason? |
RE: SCT BA 2400 & BA 2800 question
Ok received some info today you could run the BA 2400 90mm mafs with the Whipple which would be my preferred way imo. You could also use the mafia in conjunction with the BA 2400 to extend the limit if needed down the road or go to a BA 2800.
It seem some prefer to just use a big air mafs onlylike the BA 2400 or 2800 and some prefer to use a mafia in conjunction withthe mafs. I just found out also there are suppose to be some new digital multi sensor style mafs coming out mid-late March2008 for our cars. Very easy to tune for any size injector, for NA &suck though& blow thoughFI ,programmable with a USB port on board for making changes,along with other features so will be very interesting from what I understand. I think you might be saying good by to the Mafia all together if I am under standing this correctly. |
