JUST INSTALLED MY C&L INTAKE AND SCT TUNER AND MY CAR SEEMS TO BE SUCKING IN TOO MUCH AIR AND BOGS AND DIES. ANY HELP WOULD BE APPRECIATED. NEED CAR TO WORK ASAP! THANKS
yes we programmed the car. after it didnt work we turned it back to stock and then tuned it again. everything is screwed down tight. i cant rev past 2k w/o it dying.
OK, First make sure your PCV lines are hooked back up and the inlet tube did not fall off anywhere.
Where did you buy the intake and tuner from?
Who's tune is in there?
Did you give the vendor you PCM code?
Did you tell the vendor your transmission (Auto/Manual)?
Does it run fine when you return to stock?
Does it do it in neutral too or only in gear?
as long as you got it to run your probably out of the woods. I dont know what you mean by wind down noise though. what did you do to get it to run right?
