Spring Start-up
Spring Start-up
I purchased my 07 last fall and put 1,700 miles on it before I had to put her away for the winter. Spring is here and I have a question. Should I start the engine and let it warm up before changing the oil or should I drain it coldsince all the oil is in the pan? I see pros and cons on both method. Also should I spin the engine over before starting to build some oil pressure and if so, is there an easy way to deactivate the ignition so it doesn't start? Any other tips.
Thanks
Thanks
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
