Ahh crap - Shifter install
Well nothing is ever a simple as it seems. Started the shifter installation this afternoon. Quickly realized I had a problem.
The bushing on the trans arm is bulged out, partially covering the head of the bolt, so I can't remove it. Spent 15 minutes trying to push it back into place, to no avail. What should I do?
RE: Ahh crap - Shifter install
I managed to hack away at with some cutters until I had destroyed the bushing enough to expose the head. I finished the install.
It got that way because the original owner installed the steeda tri-ax, then removed it and put the stock shifter back in. When he re-installed the bushings he didn't use a washer and I guess it sort of popped overthe head of the nut. This is probably part of the reason the shifting felt so clunky to me.
Now that I have the tri-ax back in, the mechanism is precise but the NVH went way, way up. Car just roars now at high rpm, lots of noise and vibration.
ORIGINAL: Goldenpony
You might not want to hear this, but the best way to get rid of that NVH is spelled MGW. I'm glad at least you figured a way to solve your immediate problem. Good luck!
panic
09-10-2015 05:56 PM
