Mcloed Twin Disc
#31
RE: Mcloed Twin Disc
cool thanks guru
all this talk of cranks, bolts and splines,
makes me realize i'm no where ready
to order any parts!
i'm seriously thinking of a winter forging
project, in my garage.....so i'll need to
sort this mess out..
to order any parts!
ORIGINAL: MustangGT0405
Hammer - Once I know what they are I will add the info to the first page.
#32
I am not a big drivetrain guy, so can anyone explain the difference between these. I assume the last part number is the one I have been discussing since the first page. But what would the 6 bolt or 8 bolt get me?
All - Thanks for the notes. True I hadnt thought about the Cobra crank being different, or the input shaft. Hmm. Kind of changes my argument, but I still think I will stick with it just because they seem to work great. At least I will know they arent the weakest link.
Would any of the kit still be useable if I went to a Cobra Crank, and a 26 spline shaft. I understand the mechanics of a clutch system but not these intracacies.
Thanks,
ORIGINAL: 06Saleen3V
Here are the part numbers:
6 bolt twin disk (with flywheel) P/N 64306-00-03
8 bolt twin disk (with flywheel) P/N 64308-00-03
RST 10-spline (to stock flywheel) P/N 6912-03
We are working on becoming a vendor and we will obviously need a buy-in. I will keep you guys posted so we can hopefully get it kicked off.
Thanks,
If you switch cranks, you'll need to switch flywheels. You may or may not be able to use the same flexplate, depends on the kit. You'd have to check the specifics of the kits, and that's something that is far above my current level of ambition.
#34
ORIGINAL: sactown
I spoke to Mcleod yesterday and they said there is sort of bearing kit available with that kit, it makes the hydralic clutch system bleedable also, is anyone using that kit along with the RST clutch?
#35
ORIGINAL: hammeron
thanks mickey and thanks sactown
guru, maybe you can compile the part
numbers needed for a 450-550rwhp
application and list on the front page....
maestro1024
09-21-2015 02:40 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
