grantnelli CAI problems?
I just installed a grantanelli CAI for my 06 GT and I'm getting a check engine light. Is there a way to get rid of that light or should I try the stock MAF sensor? Because I have the custom MAF inside of the tube right now. Also the kit came with a resistor, does anyone have any ideas what I could do with this or would it be safe to drive this way? Any help would be aPpreciated!
RE: grantnelli CAI problems?
If you installed everything according to the instructions, then make sure that all of the CAI's connections are tight without any vacuum leaks, and that the new MAF sensor has a rubber gasket. If it's missing a gasket, then see if the stock MAF sensor's gasket can be used.
Yeah i have tried to see if all the connections are fittet and as tight as can be...but i think its something with the sensor. i tried hooking it up with the resistor but it caused the engine to lope and it killed it pretty good put unplugged that and then plugged the harness directly to the MAF the grantanelli came with. all instructions were followed to the very detail.
Contact GMS for instructions. I installed mine about 2 years ago and have never had a problem. I have since had a tune done and reinstalled the stock MAF and have no problems with that either. Good luck.
yeah i think what im going to do is scan it to see what errors i get but, i was wondering i am thinking of getting a throttle body as well for my car and i would also like to know if anyone has a good tuner i could try for this?
by the way everyone what tuners work the best for cold air setups on your vehicles? im looking for something that also gives fuel/air ratios and data logging, does anyone have any tuners like this? if so how much do they cost?
