My Eaton and 4.10s are toast
RE: My Eaton and 4.10s are toast
ORIGINAL: drbobvs
Well, since you've answered none of my questions, I'll quietly leave b/c I can't help you.
Where did you have the diff and gears installed?
A mechanic friend of mine.
If it was only 3 months ago then bring it there, why did you go to the dealership?
'cause I didn't know there was a problem with those parts until it was too late, they called me after disassembling everything!! a*holes
Why would you want to put the stock Trac-lok and gears in?
'cause the dealer kinda warned me that if I don't return it back to stock they'll void my warranty! a*holes
Which Eaton did you have, the TruTrac or the Locker?
All I know is that it has clutches not gears according to Brenspeed.
did they put in friction modifier?
Yes he did.
I wish I had gone with a Detroit TruTrac in the first place.
Thanks guys, I'm gonna talk to that shop again although it's too late.
OK, well since you're getting it under warranty just let them do it and then you can at least start from scratch with a driveable vehicle.
Perhaps the diff has a manufacturers warranty and you could start by calling Brenspeed on that too.
With an Auto you're looking to modI wouldn't go beyond 3.73 b/c of some serious traction problems, but that's just MO.
If you can't get any luck with Eaton on a warranty then I would def recommend the Tru Trac. By far, the best drivetrain mod I've done, better than the DS and even the gears themselves.
Good luck with the rebuild. BTW, did the dealership say there was plenty of gear lube in the case 'cause this sure sounds suspicious for improper lubrication.
ORIGINAL: drbobvs
and...traction with the 4.10s wasn't that bad actually but you might be right, the best 60 foot I could manage was 2.2 on stock tires.
And yes, I remember them saying something about the lubrication. I have a feeling though we'll never know the truth!!
On the other hand, the mechanic who installed my gears and diff has done this many times before with no issues, over the years he has also installed: (suspension, driveshafts, superchargers, cams, heads,...etc)
It Is Puzzling!!![sm=insomnia.gif]
I'd make sure to get those parts back from the dealership after they install new ones. Send them back to the manufacturer for replacement under warranty. If they replace them, then take them and have them installed by someone different than the first guy (if you want them in the vehicle).
If the manufacturers come back and say "It was an installation error", then get that in writing, and then go talk tothe installerabout a refund for at the VERY least the labor, and if it were me, I'd be going after him for at LEAST some, if not ALL of the cost of the parts themselves, since they were damaged by his improper installation.
+1 on 4.10's being too much gear for an automatic FI car. I think 3.55's would be just right (that's what I have in my 5-speed, and it's good). A friend has 4.10's in his 5-speed KB, and he has traction issues all over the place, even with 305 DR's..
junior04
09-28-2015 10:53 AM
Figure8allday
08-22-2015 11:11 AM
