I got a check engine light!
Man I was just bragging about how i've never gotten an error code after installing the supercharger and wouldn't you know it, it happened.
P0456 I'm thinking my $20 locking gas cap from autozone took a dump on me.
RE: I got a check engine light!
ORIGINAL: Riptide
Are you getting a check fuel filler cap message on your dash display?
p0456 has to do with the gas tank evap system. There's a small leak somewhere or the sensor is bad.
ORIGINAL: Riptide
Reason I ask is because I had a check fuel filler cap message showing up on my 06 and the dealer had to clear it off. You mentioned the gas cap, hence my question.
ORIGINAL: black07stanggt41051
off roading in a stang???????
ORIGINAL: Riptide
I had that problem a few weeks ago. The dealer cleared the codes and replaced something. I forget what it was called. Some sort of do-hickey.
