Whipple Dyno results.
RE: Whipple Dyno results.
Well, I will have to check that out then Dex.......maybe thats all it is now. I find it hard to be knock after we pulled that timing and fattened it up so much.
And yes, this is the HO kit. Mustang dyno's read about 15% less then a Dynojet. So, 387hp x 1.15 = 445rwhp on 8 psi.
Now, I've done some thinking, and gauges read vs ambient pressure. So 8 psi on my gauge is the same mass of air as 7 psi sea level being that ambient pressure here is 1.2psi less then sea level.
Meaning, I am not actually making 387rwhp......probably more like 370rwhp (about 15hp per psi)
ORIGINAL: CataclysmGT
I'm used to a 1000cc Superbike, so I would need about 800rwhp to approach that acceleration. I'm very comfortable with the power it has now that it feels like it always should have had this much . Smaller pulley goes on right away to help out a bit (put me at the same power level as a car at sea level with 9 psi, even if I show 10psi). Once the engine is built, I am sure I can approach 500rwhp and that should be plenty.
I do like being able to light up the tires in 1st without trying. With the smaller (3.375") pulley it would start to break loose in 2nd. Fun times.
I've read about that trans plate....seems odd that I wouldn't hear it before, but hear it sans Whipple.
http://www.allwords.com/word-sans.html
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
