PULLEY SQUEAK WITH WHIPPLE
I have been getting squeaking from one of the pulleys. Not sure which one only at start up when the engine is cold. After it warms up for a minute the squeak slowly goes away. What do you guys think it is? Belt rubbing on pulley? Loose pulley?
RE: PULLEY SQUEAK WITH WHIPPLE
i circled it, also if it looks fine, then
it could also be the one i marked
with an "X", since you may have replaced
the stock one
[IMG]local://upfiles/37808/628B0F59A19D4C06AE01A6CD6FC14677.jpg[/IMG]
the stock one
ORIGINAL: hammeron
the stock one
the stock one
Thanks Hammeron! Ill check it out when i get home.
ORIGINAL: nineinchnail1024
My sliding idler squeaked like a banshee about a week after I installed the whipple. Turned out, I hadn't tightened it down enough. All is well now.
