A How To: changing manual transmission fluid
Old 05-29-2017, 09:26 PM
  #151
Stoenr
Stoenr's Avatar
Did mine today following the write up, thanks! And wow, night and day difference!! Shifting like it use to! Wish I didn't put it off for like 2 years! 75k and that fluid was pretty freaking nasty!! Went with the same RP.
Stoenr is offline
Old 06-01-2017, 05:10 PM
  #152
bl817
bl817's Avatar
good luck with the RP. I do love it in everything else except my TR3650, went with Mobil1 instead. I read a lot that it ate the synchros. fill the trans to the top plug. 3.2 quarts. I know an argument is going to ensue but Tremec moved the fill hole on these to make sure you fill till full, not 1/2" lower. 3.2 quarts of your chosen oil will be at the hole. good luck
bl817 is offline
Old 06-01-2017, 10:27 PM
  #153
flash_xx
flash_xx's Avatar
I just did mine a few days ago. Used Motorcraft Mercon V ATF, buttery smooth, but this is my second change in 50K miles. With the track use I'd rather play it safe and change it regularly. I actually measured 3.2 quarts before putting it in and it didn't reach the fill hole and I made sure to empty the container completely. I put my pinky in the hole and the tip touched the oil, so maybe 1/4 inch below the fill hole. I don't think you have to be that exact, just don't let it flow out of the fill hole. I had access to a lift so the car was perfectly level, maybe that's why some people get different results.
flash_xx is offline
Old 06-02-2017, 07:04 AM
  #154
Norm Peterson
Norm Peterson's Avatar
Not to argue, but I know when I changed the fluid in mine that 3 full quarts plus 4 fluid ounces was barely up to half an inch down from the hole. Not quite another 4 fl oz put the level just above half an inch down, so I called it good (and have done several track days since with no evidence of either under- or over-filling it).
But a couple of thoughts . . .
First off, I suspect that there is some variance in the internal volume from one TR3650 to another. No idea how much, though.
Is it possible that some people actually do have a transmission with the higher fill hole while others have the lower one? If Tremec did in fact move the fill hole, it sure sounds like it was a running production change on their part with none of us knowing when it happened or how many units shipped with the 'early' hole location.
Norm
Norm Peterson is offline
Old 06-04-2017, 07:43 PM
  #155
flash_xx
flash_xx's Avatar
What oil did you use Norm?
flash_xx is offline
Old 09-28-2018, 01:03 PM
  #156
Jermski
I know this is a dead beast horse and a massively old thread. But I used this today to change the fluid on my bullitt. I modified it in one way. I didn't do anything with the stick shift. I went and bought a gallon pump weed sprayer to do the transfluid. It's sooooooo much easier. I used royal purple synchromax, and we'll see how it does. Took it around the block. I wasn't experiencing anything wrong before the change, so no rough shifts, grinds etc. The shifter got a little warm in city driving but I'm more than sure it was the catless H pipe causing heat. It goes back cool on the highway. So for the peeps doing this just follow the steps in the original post and instead of running a hose from the inside to the fill plug. Just get a weed sprayer, it's sooooo much easier.
Jermski is offline
Off Topic
22
09-11-2015 08:00 PM
Pyrate Dave
09-10-2015 07:30 PM
IronRaptor
09-09-2015 08:10 AM
M3hunter
09-05-2015 03:42 PM
Quick Reply: A How To: changing manual transmission fluid
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
