what is better on the motor S/C or ZEX
RE: what is better on the motor S/C or ZEX
I am sure this is true, but I saw a customer car on brenspeeds website that was using a 150 tune with stock internals.
http://www.brenspeed.com/customers/2006cooper.html
For a given cylinder pressure at a given rpm the engine doesnt care if its arrived at via chemical (N2O) or mechanical (Supercharger).
That said the killer with N2O is excessive cylinder pressure at low rpm. Always make sure the rpm is sufficient for the amount of N2O you are using. For a given cylinder pressure/rpm you will see a a higher rwhp with N2O due to reduced charge temp and lack of blowers parasitic drag.
logan409
09-26-2015 07:43 PM
