ANOTHER NITROUS QUESTION !!
Hey Everyone, I just purchased the nitrous express plate system, havent installed yet. i really dont like the fact i am going to have to change tunes and my plugs to run the 150 shot id like. On my 5.0 93 that i had, i did a seprate fuel system just for the nitrous, small tank in the back, holley blue pump and regualtor, i ran allot of timing with 93 in the tank and 116 in the cell. I never has any problems. Can I use this same setup for our 3v's ?
Thanks for any input
RE: ANOTHER NITROUS QUESTION !!
You might be able to make it by on an sct tune w/93+, but probably a switch of the plugs for sure. It sucks, having to try and change tunes ahead of time if you ran into a beast on the street(911, viper), but a switch of a tune at the track should be fine.
To answer your question - NO - you will not be able to run a similar set-up as your 5.0
To run that way - you'd still have to tie into the DM and harness and it would be a PIA beyond any reasoning worth even trying it.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
