dyno results...
dyno results...
just got back from getting my car dyno'd. we got the afr (air to fuel ratio) down to about 12.8 which is a lot better than the 15 it was running with my steeda tuned SCT. timing turned up a little but we ran out of time to play with it b/c i have work this afternoon.
314.9HP / 333.3 TORQUE
next week, we are installing charge motion plates and new motor mounts; also going to have a little more time to play around with the timing and stuff. he said that there is easily another 15-20HP we can get out of it right now so we shall see.
RE: dyno results...
honestly, i couldnt tell you as far as the seperate HP increase. this is the first time i have dyno'd my car and it already had everything installed. when i put on the ignition, i also changed out the gears and i noticed more power from those mods but couldnt tell you how much power increase came from each one.
RE: dyno results...
ORIGINAL: gotan05
Did the plasma booster net any hp gains?
RE: dyno results...
what he said...i dont care if the article says that it creates 12HP/12TQ or not, trust me, it doesnt. I read in a MM&FF where they modded up an 05 GT part by part and dyno'd it each time. The best increase the Plasma booster gave it was 3HP/2TQ. I was just impressed with the spark curve it creates and figured that it would be easier on the car.
Galactic
04-29-2019 02:56 PM
The01Cav
Maryland Regional Chapter
08-31-2015 04:12 PM
