Car died, no fuel pressure. Help Please
RE: Car died, no fuel pressure. Help Please
Well, it was none of the above.
Put 3 gallons in. Still no pressure.
Can hear the pump cycle with the key.
By passed the BAP. Still no fuel pressure.
Pulled the seat, removed the cover, started the car, it will idle but rough. I can feel the pumps working.
Popped the hat, and got to see part of the 3 gallons I just put in run out of the top of the tank.
Wonderful.
Pulled the pump assy, one of the lines was blown apart.
Problem found.
I didn't use the right type of fuel line when I upgraded the pump assy. So I will have to take the blame for this one.
Bought some higher pressure fuel injection line.
Swapped everything out.
Put it back together. That spanner nut is a PITA. Finally got that on.
Test drove it, seems good as new. Pressure is good across the board. DONE.........
Thanks for everyones help.
Wonderful.
Problem found.
ORIGINAL: hammeron
+1 glad you got it fixed
i know what you mean about the lock
ring.....
ring.....
I used less than 10 bad words, so it wasn't too bad. Ha...
MEISTERSNFB
03-31-2020 07:50 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
