CHE K-Member Brace w/ Torque Limiters
I was looking at this and wondering if it was worth it. I've read all the posts I could find but I'm still not sure. I never had a problem missing shifts with the stock shifter but I'm worried If I try shift hard with the Hurst at redline I'll miss. So, is this a big improvment and a help for a short throw like the hurst? Also does the K-member help handeling at all? Are there any downsides to this like stiffness, noise etc....
Also I read one post how this broke the transmission bolts on someone's car. Is that something to worry about???
RE: CHE K-Member Brace w/ Torque Limiters
i've never had any problems w/. my che k-member w/. the tl's. i can say that, like you, i didn't have big problems missing shifts (i have a pro 5.0 short throw), but it did happen on occasion. i never miss shifts now. the k-member does make a difference and help to stiffen the chassis, though probably only minimally; i think the bigger gain is in weight loss (though i'm pretty certain we're talking nickels and dimes, so to speak). i'm no expert and could be way off, but this is my experience so far. imo it's worth the $$.
Yes the K.member brace w? TQ is awesome and highly recommend..
If u go with a entire new K-memeber is weight..about 40-50 pounds i think whick is alot..As far as handling yes becuase with new A-arms
as well unsprung weight is much better..
But i would def..get the the CHE
I must have 12k miles on mine and never had a problem. If you don't adjust them right they can cause a vibration. I tried leaving them off after my clutch install, but just didn't like the way the car feels without them.
You want to shorten them a little after they are installed, but not to much. Just enough to start pulling on the transmission.
You will feel the engine more, especially at start up.
How do you know how much to adjust them, is it easy? Also from other posts I've read-do they unadjust themselves and is locktight needed for anything? Lastly As far as the install from other posts I'm guessing it's a pretty easy job right? Thanks alot guys!!!
ORIGINAL: VistaGT
The install is not that hard, but there was a rather large bolt or nut that needed removing. I remember thinking that the average person isn't going to have a socket that size.
Thinking about it, it maybe better to shorten one side and lengthen the other. Which side does the engine torque over torwards, passenger? It would seem logical that if the engine and transmission is torquing over torwards the passenger side, then you'd want to shorten the drivers side limiter and lengthen the passenger side, otherwise your drivers side limiter is doing all the work.
Anyone think i'm making any sense? Does anyone have there's set up this way?
+1
I'll be putting on the prothane motor mounts this weekend
ORIGINAL: hammeron
i installed mine, even after seeing andrews
broken block
i would say tho, if you're not missing shifts,
then you should weigh the risk vs. reward
broken block
