Cleaning Filter/MAF
#23
RE: Cleaning Filter/MAF
ORIGINAL: moosestang
What kind of brake cleaner leaves a residue? That would totally defeat the purpose of brake cleaner.
ORIGINAL: Z06 Killer
I agree and a further note would be that it could leave a residue on the MAF sensor and give incorect readings.
Its for cleaning hardware before the use of LocTite.
[IMG]local://upfiles/69445/F976A80EDACD43D38FA12C6DFCF16272.jpg[/IMG]
[IMG]local://upfiles/69445/682E5CDA5A684F7D8F447422DA3977E5.jpg[/IMG]
#24
Bought a MAF cleaner and cleaned it last night. Very easy process and dries fast. I bet it's brake cleaner.
Cleaned the TB also, did not remove it, however. Too chicken to screw something up. Engine seems to run a bit better. Probably psychological.
#25
#26
Using a Q-tip on the MAF is playing with fire IMO.
I guess the reason I wouldn't spray the MAF with the brake cleaner is because it disolves so many things. Being the MAF is a computer sensor, there may be stuff that could be damged using the brake cleaner.
I used TB cleaner to clean my throttle body, but would use brake cleaner if I needed to.
MAF cleaner for the MAF.
Like someonelse said, I wonder if it's all the same?
#27
I personally think they seem pretty much the same, but in reality who are we to guess? They may have one ingredient difference, but that may be the one ingredient that messes with the MAF, maybe damaging it? I just spent the bucks on a can of MAF cleaner and just used brake cleaner for the TB... no problems yet, and doubt there ever will be...
#29
ORIGINAL: AmericanMuscle4.6GT
NO BRAKE CLEANER ON THE TB, OR THE MAF. ONLY BRAKE CLEANER ON BRAKES.
USE MAF CLEANER ON MAF, AND TB CLEANER ON TB. jesus christ, it only costs $2.99, how hard is it????
I should come out with my own line of clutch cleaner.
