Hard Starting part 2: Possibly a starter issue
When the car was starting hard before, it would crank a couple of times and then I'd hear a "bussing" sound for a 1/2 second or so before the car fired up. Today, I had to try 4 times to get the car to start. The first two times, it cranked 2-3 times, made that "buzz" noise.....and that's it. Even with the key still turned to start.....the car did not continue to crank. The third time, same noise, but the car tried to start (sputtered) and the 4th time it fired up but idled a bit slow at first. Black smoke with successful starting.
New theory: since the car does not continue to crank after failing to start (even with key in "start" position) I'm thinking the starter is disengaging from the ring gear. The buzzin noise would be the starter spooling down (a noise you don't normally hear because of engine noise). Starter failure (or relay) might explain why I had no problems for the first two weeks with starting after the supercharger install.
Going to a local mechanic tomorrow to show off the car, (he built a bad *** pro-street engine for a '68 Hurst Cuda when I was changing oil for him at his shop few years back) and get an opinion.
RE: Hard Starting part 2: Possibly a starter issue
Nice ride! Sounds like either the battery or the starter may be a problem. A bad cell in the battery can cause a low voltage problem while cranking. A bad starter can pull too many amps and also cause a low voltage problem.
The car's computer will not respond favorably to either. Best to have it checked out at a shop.
Have someone check the voltage at the starter when it's buzzing. Might be the battery like jerjan suggested or a bad connection at the battery or down the line to the starter. Starter should turn the motor till the battery dies.
Voltage meter doesn't drop, and I should get an error message if it does drop. I would expect it to be consistent if it was the battery. The "buzz" isnt your typical low battery hum and it only lasts 1/2 second. Monday I will have the shop take a good look. I'd be happy if it was just the starter. Haha.
Just a thought - I had a similar thing in my '70 (I know, way different car), but it would buzz the starter solenoid but not crank. Turned out to be the battery terminal itself - was passing enough voltage to run accessories fine, but not enough amps.. and it could be that the few times you could get it to start there may have not been enough amps to fire the ignition reliably until the alternator caught up, or you had it partially flooded, or the computer was wiggin out..
