RST Clutch ship date pushed back again!
RE: RST Clutch ship date pushed back again!
ORIGINAL: hammeron
do you think the OEM slave cylinder will
hold up well, with higher clamping force
pressure plates
pressure plates
That was the plan but I am getting tried of waiting for that damn clutch.
bearing kit: MCL-14-301
Clutch: MCL-6911-03C
Those are summit racing part numbers, I would call and verify numbers or you can go here which is where I placed my order,
http://dagostinoracing.com/index.php...ducts_id=15140
They are much cheaper.
ok this is good to know, it's also
got me thinking i should go
mcleod, just for a little more
insurance
insurance
ORIGINAL: moosestang
The spec stage 2 pressure plate has 30% more clamping force
than stock, so it's safe to assume that it's 30% harder for the
stock TOB to release it.
Here's the stock TOB without the dust cover. As you can see it does have a plastic shaft. I'm not sure how much extra pressure it would take to crack it, but it's definately possible. I'd be more concerned with over compressing it by using a spacer or over extending it by having a flywheel/pressure plate combo that's is not correct.
Here's how it normally looks when on the transmission.
I'm surprised the bearing on these don't wear out more often. I've seen better bearings on skate board wheels.[:'(] For those reading that don't know, the head of the TOB (part i'm pushing down on) spins around with the pressureplate/flywheel and it is normally compressed like shown until you press the clutch pedal down.
i'm glad you explained this, because
i've been wondering how the slave
contacts the pressure plate fingers
as they're spinning
thanks moose
as they're spinning
thanks moose
Too bad I didn't live in Florida, I would ask you to help change mine, the service expense is killing my car funds!
On the TOB, I have no idea what Ford was thinking when they designed that thing, plastic come on now Ford you should know better.
But I think the Mcleod bearing kit along with a different clutch would solve my issue, if I could do the work myself (no tools, room, or time), I would try just the bearing kit with the existing Specs II combo just to see if it fixes the issue.
New price and part number for RST
679 from Jon for clutch part number 6913-03 bearing kit 450 (didn't get part number he had to pick up his kid) At that price I think I will just drive around pissed off until it ships.
[align=center]Jonathan@HilbishFord [/align][align=center]2600 South Cannon Blvd[/align][align=center]Kannapolis Nc 28083[/align][align=center]704-938-3121 ext 35[/align][align=center]fax 704-933-4867[/align][align=center][/align][align=center][/align]
