1st gear or clutch Rattle?
In first gear when feathering the clutch peddle say going through a fast food drive through where you can hear it more I get a annoying rattle or gear noise only when going slow in 1st I took the car to a ford dealer and they said it is normal? I am going to take it to another dealer to get a second opinion or test drive another manual s197. Anybody also have noticed this!?
RE: 1st gear or clutch Rattle?
you are talking about the chatter right?? i get it to on a very very slow roll feathering the clutch, i've learned that im just letting the clutch out a little to much when feathering it and have it to the point of almost fully engaged but slippin it a lil...... its hard to explain but i know exactly what your talking about... try when slipping it to keep the clutch pressed a little more than you normally do when slipping it, that should stop it, at least it did for me.
Wow, this thread jumped right out at me. I have the exact same problem, and have also been to a dealership who passed it off as normal. This is not a clunk so much as a combination of a chatter with a rattle that is noticable when starting off, I would say from 1k RPMs and below. I've found it gets a lot louder/worse once the car is fully warmed up, in fact, often times I can't even reproduce it when the car is cold.
Please keep us up to date if you find the cause and/or solution to this one. It's really annoying and sounds like something's going to fall off my NEW car [:@]
ORIGINAL: HypromanGT
Okay, I guess I'll live with it if I have to. Anyone know WHY or WHAT is rattling?
EDIT: (Thanks Moose and Brian)
AmericanMuscle4.6GT
11-10-2015 02:06 PM
ccdguy
09-19-2015 05:20 PM
