X or H pipe that won't give error lights? (Cat removed)
I've heard that the 08 mustangs if you run a offroad H or X pipe with out the cats you'll have issues with a check engine light on the dash? Is there any that won't cause any trouble? or must you have some type of cat weather stock or a high flow?
RE: X or H pipe that won't give error lights? (Cat removed)
You need cats of some kind to keep the check engine light at bay! but im sure youll end up buying a tuner eventually ( the moddingbug isgonna getcha sooner or later ) ..so just have it turned off in the tune and no worries!
Cel will come on for offroad setups. A custom tune or mils would help you out. Tune would be your better choice. You might even get a cel eventually with a high flow.
Yeah I figured that if the cats removed the lights coming on, just asked to make sure..
Trying to learn all the lingo here, as with any group of a set subject theres always special lingo, and since I'm new to not only the forums here but Mustangs.
Thanks for the answers guys..
[align=left]
So does that mean the MILelminators that Brenspeed sells won't work? If this is true you just saved me $80.
ORIGINAL: cbrstng08
[/align]
No i already tried MIL's, they dont work for '07+. You need a tuner.
[/align]
