Do you have a Saleen SeriesVI?
RE: Do you have a Saleen SeriesVI?
Everything has been installed and I get to pick ny car up tomorrow. 466rwhp on JDM's canned tune. Upgrades: Saleen SC, GT 500 fuel pump, 60lb injectors, new Saleen Ultimate air kit, 3.2 pulley, v10 water pump pulley, gapped HTO's, line kit
Saleen SC
39lbs injectors
3.8 pulley
Steeda CAI
FRPP Pumps
FRPP 4.10's
BMR LCA's
BMR Relocation Brackets
Prothane Motor Mounts
Pro 5.0 shifter
Spec's II+ Clutch
Spec's Aluminum Flywheel
Mcleod Throwout Bearing kit
MT's ET Streets (track only)
438rwhp
391rwtq
39lbs injectors
3.8 pulley
Steeda CAI
FRPP Pumps
FRPP 4.10's
BMR LCA's
Pro 5.0 shifter
Spec's II+ Clutch
438rwhp
391rwtq
Whipple guy here.....sorry to hijack but have any of you considered forging with the excellent numbers you guys are putting down...that's my plan.....seems it wont happen until next year but I read thru most of the posts and did not see one that was forged....just curious.....sorry back to topic..........Oh sactown hope all is well and the car is running the way it should for you! Did the throwout bearing work for you?
The throw out bearing and mounts are being installed as we speak. If that does not fix the issue it will be a new clutch. I got tried of waiting for that damn RST clutch 3 months of back order[:@]. From what I am hearing the bearing is fixing the problem, so I am hopeful. Other than that the car runs great won the street class at mustang maddness a couple of weeks ago trouphy and $250.00
My previous 05 I just sold had a Saleen Series VI: ...here is what I had
AUTOMATIC GT
avg boost was 7.5 to 8...cold days I peaked up to a hair over 8 psi
422rwhp 416lbs torque
custom tuned by vmptuning
saleen series VI
3.6 pulley
39lb injectors
saleen extreme intake boot
C+L Conical air filter and heat shield
lightning 90mm MAF
Kooks LT headers
Catted X pipe
Borla stingers (FRRP)
that was it in a nutshell....she loved to scream....good luck with your project..
AUTOMATIC GT
saleen series VI
3.6 pulley
39lb injectors
lightning 90mm MAF
Kooks LT headers
Catted X pipe
mungodrums
09-28-2015 10:54 PM
