JBA vs BBK shorts
RE: JBA vs BBK shorts
The JBAs also seem to produce more power, based on the research I've been able to do. On similarly modded motors the BBKs were good for about 5 HP and a max of 10lb of torque. The LBAs were good for 20+ of each.
Other than that, ic an't speak to the quality of either fo them.
ORIGINAL: kcmarti
The JBAs are tuned headers with equal length primaries. The BBK headers just have primaries that flow better than the stock manifold, but are not "tuned".
Everything I read says they're tuned. Tuned meaning each tube is of equal length.
I just had the JBA shorties installed last week, and I really like them. I'll be making a dyno run as soon as the dyno is repaired, (next week I hope) and I'll post the results. I picked them because they are tuned equal length (or very close to it) the BBK's were not equal length tubes (at least the ones I looked at) plus the dyno charts I saw showed the JBA's made more power especially on the low and midrange. There is a similar thread running in the drivetrain/performance section you might check out. I hope this helps!
[align=left] [/align]
I have read many good reviews on both types. I like the BBK's and you can get them equal length or "tuned" as stated before. Make sure you get them ceramic coated or titanium coated (JBAs) as well regardless of which you go with. I am leaning towards the BBK's but many have the JBA's so I guess personal preference.....
I am not a fan of dyno results that the manufacturer puts out on any header as they always seem to trump them up to sell more units....that is just one car that they posted the results for and not all cars are created equally from the factory (even with similar mods).... JMO
I'm screaming BULL$HIT!
It's just not possible that the JBA's produced a 20+ h.p. increase on a nearly stock motor. Their ads used to say 27hp and if you read the fine print..........*with cai and tune*
IMO the only reason to go with the JBA's is because of the smog legality. I've had BBK's in the past with hit and miss results as far as quality.This was as recent as '02 on my last fox body (my Cobra has JBA's lol), so whether their quality has improved or not isn't for me to say.
junior04
09-28-2015 10:53 AM
